Old 08-01-2020, 07:03 AM
DLFlyer DLFlyer is offline
Default Bracket dimensions 23
Iím sure there are several threads on this topic already, but I wanted to see if anyone share their bracket dimensions with me. Really just curious about setback and degree.
I have friend with a bracket that he will sell me I just need to make sure it will work. Whatís the proper way to measure the degree?
Old 08-01-2020, 08:14 AM
flyingfrizzle's Avatar
DeadRise Ho
Most 23s measure 12-13 degrees, if your transom is rotted and sagging it may measure 14 degrees. Ive seen them sag back some even with new transoms that have been redone. They glass the core in and gravity sags the top out more and if you don't clamp a stright edge for support it can cure that way. To check your you can buy an angle finder or simply measure using a 24 inch square. Take the square and place the long side on the hull bottom at the keel and the short end pointing upwards like in the pic below. Each 1/4" shown equals one degree. So 3" would equal 12 degrees. Far as setback, most are made 30 inches. You can go as short as 24" but some outboards will not tilt all the way up. the shorter the better sometimes with balance.
68 27' SeaCraft Race Hull
68 27' SeaCraft Seamaster
71 20' SeaCraft CC sf (sold)
73 23' SeaCraft CC sf (sold)
74 20' SeaCraft Seafari (sold)
74 20' SeaCraft CC sf (sold)
75 23' SeaCraft Sceptre (sold)
76 25' SeaCraft Seafari
78 20' SeaCraft CC ma
Old 08-01-2020, 10:24 AM
Thank you very much. That’s helpful. As far as measuring the existing bracket, are there any tricks for that? What should the angle of the after most part be where the motor will be hung? 12-13 degrees?
Old 08-03-2020, 07:15 AM
DeadRise Ho
Originally Posted by DLFlyer View Post
Thank you very much. Thatís helpful. As far as measuring the existing bracket, are there any tricks for that? What should the angle of the after most part be where the motor will be hung? 12-13 degrees?
The ones I have built the outboard mount ear angel is parallel to the transom angle. I would think most other factory made ones would be similar.
Copyright ©2000 - 2020, vBulletin Solutions Inc.
All original content © 2003-2018 ClassicSeacraft
