Old 12-04-2018, 12:39 PM
bibijawa bibijawa is offline
Default First year to go no wood?
In what year did seacraft go no wood? Are there any known problems with 2006 23s? I've read bad or sloppy wiring but how about build quality issues?
Old 12-04-2018, 01:36 PM
Pretty sure it was 1998 when they left Florida, bought by Larger company, can’t remember name. Own Mako, and a few other brands which may or may not still be in production. I visited the plant in Forest City, NC around ‘04 or ‘06, pre ‘08 crash which may have shut the whole plant since. IIRC, the wood shop was impressive, and I believe wood was still going in the Mako’s only.
Vezo
Old 12-04-2018, 10:05 PM
Default Maybe CSY Yacht
At one point think SeaCraft was bought by CSY Yacht, seem to remember that name. Just one name in a string of owners, but the only name that came to mind.
________________________
'76 20' Seafari, ordered in '76
17' Larson Volero
14' Fabuglas
14' Lyman lapstrake
8' Minimax, at age 14
Old 12-06-2018, 05:24 PM
captainDH captainDH is offline
I have a 2005 23, zero issues. Not even spider cracking on the fiberglass. These bass pro era boats get a bad rap but I truly believe the issues were hit or miss, and mostly on the 25s and 32s. The 20,21,23 seemed to be relatively problem free. Please correct me if I am wrong, but the coolest thing about these red headed stepchildren is that I have yet to see one gutted and rebuilt, simply because of the fact there is no wood in them. With that said, 30 years from now I might be eating crow. So not fair to compare to potter era boats as these boats are only 20 years old max. But they ride the same (I have ridden in both), and I love the changes made to the front deck with more storage, and the centerline box is just plain massive. The stern is nice as well, you can throw flip flops/ dock lines out of the way under the splashwell. On sandbar days, I can easily fit a fortress FX7, my stern anchor, under there as well. Very similar to the albury brothers transom design. I have know regrets, and most peeps that see it say “great job on the restoration, beautiful seacraft”
I just smile and say thank you, my ego would get smashed if I admitted it was a pos “Bass Pro Special”, lol
Old 12-06-2018, 06:23 PM
Administrator
I've seen a couple of these 25's and they look real nice. The only thing I didn't like about the newer 21, 23, 25 was the lack of fuel tank access. There's no hatch for replacing the tank when the tank goes bad.
Old 12-07-2018, 07:17 AM
agreed, crossing fingers on this issue... on the contrary, because everything is seemless, no caulking/screws, all solid one piece floor, hopefully retards and restricts all the usual symptoms that can cause failure. Certainly will cry if/when the day comes i start smelling fuel in the bilge.
i do know of a 2006 23' that needed a tank replacement, spoke with owner. it was a $5000 problem.
most all of the newer boats of the 2000 vintage or newer, regardless of brand, do have seemless cockpit floors.
Old 12-13-2018, 11:05 PM
Joe R Joe R is offline
I know my 1998, 21 (first year of the newer 21) is all composite no wood , 3 piece construction, owned by Tracker but made by Silver King in Fl....I purchased mine in 2015 after the old owner updated the whole boat wiring, updated electronics, motor etc...but I had some water in fuel problems that could not be found,,,so I put in a new tank...yes no hatch to access tanks in those years,,,we had to un rig everything, lift the console with t top attached , cut the floor,,replaced tank with a poly tank and put everything back together...HOWEVER the old tank was in good shape , the water problem was due to the fill and fill hose...well now EVERYTHING but the hull itself is new as of 2015...I have NO cracks ,voids , blisters at all in the glass, very solid feeling boat floor and deck is like a rock... Love the boat,,PS I had a 20 Potter for 35 years prior to buying the 98 21
Joe R.
21 SeaCraft 1998/ 200 Optimax
Susie 2
Joe R
Old 12-17-2018, 06:47 AM
bigtahuna bigtahuna is offline
I also had a water in the fuel problem on my ‘98 23. I stuffed the fuel fill hose with tissue put the cap back on and hosed the gunnel down. The tissue was soaked when I opened the filler. I put in a new filler assembly and have had no more problems with it.
Old 12-17-2018, 09:34 AM
that was a problem with those vent and fill combo caps...Mine was getting water in it The fill hose under deck is long and has a bow and low spot in the hose...when it rains or wash down the boat water sits in the fill hose in that bend , then once you plane the boat that water runs into the tank
Joe R.
21 SeaCraft 1998 / 200 Optimax
Susie 2
Joe R
Old 12-19-2018, 07:36 AM
DonV's Avatar
Cheap Bastard
How true, I had one of those Perko fill/vent combo gas filler caps and the O-ring was missing, took quite a while to figure out where the water was coming from. New O-ring a bunch of marine grease and fixed. That being said I'll never have another one, pain in the ass to fill.
Copyright ©2000 - 2019, vBulletin Solutions Inc.
All original content © 2003-2018 ClassicSeacraft
