Old 06-12-2019, 10:59 AM
Beaver Beaver is offline
Default 23 Bow Rise
A friend of mine recently bought a 1987 Seacraft CC. The boat is an absolute gem. No bottom paint and not a single stress crack. It also has a Suzuki 250 on an Armstrong bracket (non floatation).
When you first accelerate the bow rises up quite a bit before laying down. The boat rides well once underway but I am wondering if the bow rise is normal for this boat?
Thanks for any suggestions.
Rob
Old 06-12-2019, 11:18 AM
FLexpat FLexpat is offline
OOPS - just realized its a DF250 on a nonfloatation bracket.
I deleted comment about the AV plate position.
Tabs might help but he probably needs a floatation bracket
Last edited by FLexpat; 06-12-2019 at 12:05 PM. Reason: didn't read carefully before typing...
Old 06-13-2019, 07:50 AM
Administrator
The problem is 650lbs on a 3ft lever.
flotation brackets have more surface area and act like a giant trim tab on the take off which limits bow rise.
without changing your bracket or notching the transom, here are a few suggestions that will help somewhat.
1. Redistribute weight. (move weight forward, lower the better)
2. Add wedges
3. Use a sternlifting prop like Mirage Plus or Rev4
4. Install a Permatrim or Cobra marine plate
http://cobramarine.com/
https://www.permatrims.com/category_s/63.htm
5. GIANT trim tabs
Old 06-13-2019, 10:33 AM
kmoose's Avatar
Giant trim tabs.... kill two birds with one stone.
1974 23 Tsunami w/ 300 Suzuki
Old 06-13-2019, 11:20 AM
Thanks guys!!
Copyright ©2000 - 2019, vBulletin Solutions Inc.
