Old 09-13-2020, 04:53 PM
jsylvester08 jsylvester08 is offline
Default How to drain Front Fish Box 86’ 20’ SF
We have had some rainy days here on LI in last few weeks and my fish box has about 2 inches of water sitting in it. Why is the best way to drain it without putting it on a trailer? I keep her in the water all year and was wondering if everyone pulls the plug when running on a plane or if that part is still Uly Der water. The drain goes down though the hull below the water line. I leave a plug in at all times and don’t want to pull it if it’s only going to let water in vs draining. Any help would be appreciated. Also has anyone set this up to drain into the bilge? When did you put the new drain hole if you did?
Thanks for the help.
Old 09-13-2020, 09:03 PM
Antique Slacker
Pull it on plane.
Old 09-13-2020, 09:27 PM
bumpdraft's Avatar
With no waves, or you might get a shower.
Old 09-13-2020, 09:32 PM
PackRat's Avatar
PackRat PackRat is offline
Assuming the same as my ‘74 20 SF, i pull the plug so it will drain when in the slip. Rain water from down pours will find its way in. Water only lays in the area just at the top of the thru hull. Before I leave , I plug it so salt water doesnt shoot through the hole. Typically use it for storage as I have a cooler and kill box in the transom if needed.
Old 09-14-2020, 10:15 PM
strick's Avatar
And when all else fails don't forget the shop vac
Old 09-28-2020, 12:47 PM
Bwana4 Bwana4 is offline
putting the bow up on a small sandbar exposed the bottom hole, so you can pull plug
Old 10-03-2020, 09:04 AM
Default I’ll give it a try
Thanks all for the input. Going to give it a try this weekend.
Old 10-22-2020, 12:36 AM
Default Thanks
I guess sometimes the easiest solution is the best solution. I put her up on a plane pulled the plug and was shocked to see the water start to flush out. Th also all for the input. This has been bothering me for 5 years since I bought her.
Old 11-25-2020, 06:09 PM
HatTrick's Avatar
HatTrick HatTrick is offline
I also have an '86 20sf. Has anyone found a way to waterproof that hatch and the deck hatch aft of the leaning post?
'86 20 ft CC with 4-stroke 150 yamaha
Old 11-26-2020, 08:21 PM
rcnight's Avatar
rcnight rcnight is offline
Speaking of fish boxes, my 83 SF drain is not original. If you have the original setup, could you post pictures of the interior & exterior. Thanks
Copyright ©2000 - 2021, vBulletin Solutions Inc.
All original content © 2003-2018 ClassicSeacraft
