Old 06-10-2022, 06:02 PM
AndrewDolan AndrewDolan is offline
Default 20' SeaCraft inboard - Potter Hull
Trans id: 5YL12307RR0969137
20' Sea Craft - inboard - center console - Potter hull
Mercruiser 5.0 MPI
Velvet transmission
33 gallon aluminum fuel tank
Aluminum trailer
Fuel water separator
Cushions forward, aft, and leaning post.
Hydraulic trim tabs, Garmin
Stereo FM/CD
Drip-less stuffing box
Hose hook-up (rinse and winterize motor)
Boat and trailer are turn key.
Located in Essex, NY (Lake Champlain)
Asking $20K - OBO
WakeSurfer
Last edited by AndrewDolan; 06-14-2022 at 08:19 PM. Reason: image is 90 degrees out and typo
Old 06-11-2022, 09:43 AM
77SceptreOB's Avatar
Very unique. Never seen a 20' SeaCraft inboard before. Noticed it doesn't have a hull pocket drive, so must be an aftermarket retrofit. Looks good though. Any performance info you can share? Cruise speed, WOT speed, fuel burn rates?
GLWS.
Jim
1977 SeaCraft 23' Sceptre W/ Alum Tower & 2020 Merc 300-V8
Old 06-11-2022, 05:12 PM
lollygagger
I never heard of one either. All brochures say 20' was available in either Stern Drive or OB. The 23' was different. What is your Hull Number? That will tell was it either a Master Angler or Superfish.
"Life is not a matter of holding good cards, but of playing a poor hand well."
-- Robert Louis Stevenson,
"LIFE, LIBERTY and the PURSUIT of a Classic SeaCraft" -- capt chuck
Old 06-12-2022, 12:43 AM
Great looking boat
Old 06-12-2022, 05:45 AM
This SeaCraft was purchased at an estate sale in'06 and I was told it was originally a stern drive.
It had a new 350 crate engine (2 barrel) which I replaced with a 5.0 MPI (fuel injected) in 2016
I will get the hull number etc when I return to Essex, NY later this month.
Andrew
WakeSurfer
Old 06-12-2022, 06:51 PM
Fr. Frank's Avatar
Back in the early 80's when I managed Waterway Marina, I took in trade and resold a '76 20' SF that had been converted from sterndrive to inboard. It was powered with a 350ci/260 hp Mercruiser motor under a console taken from a Robalo. (it still said Robalo on it). The keel at the stern had been cut flat about 6' forward of the transom. I remember it had a very small diameter propeller, maybe 12 inches or so. I took it out a couple of times and it rode VERY flat and was a really wet boat in any kind of chop at all. It was, however very, very quick to plane off and then topped out at about 38 mph.
Fr. Frank says:
Jesus liked fishing, too. He even walked on water to get to the boat.
And we still tell His fishing stories!
1987 18' Superfisherman 2017 90 Etec
Old 06-27-2022, 04:46 PM
Default 20' SeaCraft - CC - inboard - Potter Hull
I.m back in Essex, NY and can show this SeaCraft.
Still not sure which model this boat is/was.
This Seacraft was built in '73 and was originally powered by a 4 cylinder stern drive.
Where is he hull id on older SeaCrafts? Thanks - Andrew
WakeSurfer
Tags
center console, custom inboard, fuel injected, mercruiser, trim tabs
Copyright ©2000 - 2022, vBulletin Solutions Inc.
