  #51
Old 09-14-2021, 11:12 AM
Originally Posted by Locke N Load View Post
If you endorse G10 then I won't question it and order some up. How thick? I think the heaviest item will be the dual bank battery charger.
My thinking with the Coosa is it is already 3/4" thick. Adding a couple of layers of glass and it is getting pretty thick and taking up valuable real estate. Also, I am running low. I could try patching together a bunch of the scraps. I was just thinking I have enough material to make the frame and I could make panels of straight glass to complete the box. I do have some of the Carbon Core honeycomb leftover I could use and it is economical enough to order and ship more if needed. Hmmmm...
You can layup your own glass panels if you didnt wana order g10. 3/8” thick is plenty. You really dont need a full size piece, just some squares where the mounting fasteners are. That will raise it up a bit for cooling too.
Use the coosa for the helm area and whatever ya got for the rest. Honeycomb isnt ideal for that cuz you cant just round over the corners. Framing a box is just too much work and over-engineering, and shaping the corners will be a royal pain. Build the box with cored panels, fillet and tape the inside.
Most of the time ill try and screw my ziptie mounts into or close to the filleted corner. Keeps all the rigging tucked into the corner and theres plenty of meat to hold the screw…
Old 09-14-2021, 12:01 PM
Locke N Load Locke N Load is online now
I made the passenger side bulkhead separating the deck area from the cuddy area with 1/2" CC honeycomb and a couple layers of 17 oz. biaxial on each side. It is quite stiff and not having to worry about corners made it relatively easy. Then I made the seat/hatch covers the same way. Lots of edges meant filling the honeycomb with thickened epoxy and then wrapping glass tape around, several layers thick. More work than I expected, but plenty strong again and fit well.
I am planning on making the entire face of the helm where the steering pump, electronics and everything else will be attached to ensure it is plenty strong. Then I was figuring the frame for the rest of the helm box with Coosa. Maybe I can see if I can locate some more Coosa locally. I found the three panels I have used off Craigslist for $660. That's about one panel now with shipping.
I like the idea of making my own G10 style glass board. That should be easy enough. I have found the 17 oz. material ends up being 1/32nd of an inch thick each layer. 12 layers won't take long to do.
Thanks for all the tips and suggestions. Much appreciated.
1971 Seafari 20 - a work in progress currently
Old 09-14-2021, 05:51 PM
jbass03 jbass03 is offline
If you still have any scraps of demoed boat(the original side of the deck liner work great) you can stack them and use thickened epoxy to stick them together to make cheap G10.
Old Today, 04:30 AM
strick's Avatar
Boats looking good. Your stringers came out nice...almost a shame to cover them up lol
Strick
Copyright ©2000 - 2021, vBulletin Solutions Inc.
All original content © 2003-2018 ClassicSeacraft
